Is this timing belt, water pump & seal kit OK?
I'm on a budget so if this stuff is fine the price is sure right.
http://www.ebay.com/itm/96-00-Honda-...#ht_3099wt_955 Thanks |
Just info, I use Honda timing belt, seals and pump. never had a problem at 260k. 02 civic.
Just remember, you get what you pay for. This is a big job and you don't want to use inferior parts, plus aftermarket part don't last as long and don't fit as well, something to think about.
http://eddiecarrara.hubpages.com |
I agree,this is a major part,if it fails the engine is toast.
i would use napa brand over that ebay kit napa uses gates belts which manufacturers most honda belts in the USA. my timing belt,water pump,valve gaskets,all belts and timing belt tensionr are napa brand 50,000 miles no problems.
And Napa carries a lot of items that Auto Zone and Advance don't.
You can't beat genuine Honda parts, just saying!!!
Well someone has to make their.
Well after some research I did purchase that kit from ebay along with new front struts and a tune up kit. Other than the items in this kit I'm thinking about a thermostat and a new battery. I still need a used / aftermarket front and rear bumper cover, a front right fender and a left rear outer tail light.
So this is what I have coming (I know there not perfect but there what I can afford) http://www.ebay.com/itm/160668525469...#ht_3099wt_955 http://www.ebay.com/itm/220906338978...ht_2043wt_1188 http://www.amazon.com/gp/product/B00...00_i00_details |
Looks like some good deals,good luck.
