Timing Problems
First of I just want to thank you guys for all the help as I use this forum for just about anything I need to do. If I'm posting this in the wrong area just let me know and I'll fix it. With that being said let's move on to my rough week..
96 Honda Civic D16A SOHC On my way home from work, the crank pulley flew out from underneath my car, obviously the bolt and woodruff key were nowhere to be found but I retrieved the pulley. The crank gear started backing off the shaft and my timing belt came off. I did try not run the car after the belt came off. The crank gear wasn't in the slot so I removed it and placed it back on there correctly. I turned it to TDC. The cam gear is not at TDC and I don't have the belt on there. My question is, how do I get this cam gear to TDC without this belt as that's how I would typically do it. It won't turn by hand and I don't want to force it resulting in bent valves. Do I need to loosen the rocker arm bolts in order to be able to move the cam gear to TDC? Sorry if this is a dumb question. I tried to find it on this forum before asking but didn't find anything. |
your valves are most likely already bent among probable cylinder head damage. sometimes you can avoid damage if it skips a tooth or two but a complete failure always causes permanent damage if not your the luckiest person ever.
