v-tech head
my brother inlaw just bought a 93 honda civic dx&nbsp\\;1.5 hachback canadain&nbsp\\;that the dealer said hand ony a bad fuel pump got it replaced and would not spark well it was the disrubeter&nbsp\\;since they put the coil in it it seems to go out, but then i could not get the timing right tried and tried . relized that #3 was not getting compression. Now i wonder if a 1.6 v-tech head will fit on a 1.5 will the same intake mount up and will the&nbsp\\;sqame exust&nbsp\\;
RE: v-tech head
As long as the head is a D-series head it will bolt up fine. If you want the VTEC to work you wil need to hook up a controller. D16xx head will bolt onto D15xx block. You will need to get the right head gasket and timing belt. Some swaps even require getting an adjustable CAM gear since this swap tends to set the timeing off by half a tooth. There a tons of resourses on the web for this swap. I'm sure there are many threads on this forum even.
Good Luck JoSh |
RE: v-tech head
It will definitely mate up with it, just have to hook up some electrics and you may want to look into a new cpu from a car with vtec.
