-   Honda Civic Forum (https://hondaforum.com/forum/honda-civic-forum-12/)
-   -   wagovan 4wd (https://hondaforum.com/forum/honda-civic-forum-12/wagovan-4wd-844/)
jw_shade Nov 24, 2006 08:50 PM
wagovan 4wd
any information or tech links regarding the rare civic 4WD 6-speed would be greatly appreciated. looking to do engine swap. any possibilites or suggestions welcome. in particular, vtec compatibility. thanx
josh2113 Nov 25, 2006 01:48 AM
RE: wagovan 4wd
Assuming you have a 4th gen. civic (88-91)....
I do not believe there are any hang ups on hooking a d-series vtec motor to your trans. And you could always do the mini me swap. Just need a head off of a 5th or 6th genration civic w/vtec pretty much bolts on with a little modification and then you just have to set up the vtec controller. This is also assuming you have the 1.6 liter w/multi-port fuel injection. Vtec does not like the duel point set up on the gen 4 civic with the 1.5.
jw_shade Nov 30, 2006 07:24 PM
RE: wagovan 4wd
thanx. have yet to do a swap myself. so i may be in touch
James4.0litre Dec 5, 2006 01:55 AM
RE: wagovan 4wd
I had a van for a while, it had shag carpet, a small bed in the back, smoked out windows and wide tires, yeahhh..
