Window INOP.......
2001 CIVIC COUPE. Passenger window went down cannot get it back up tried both switches. Which way do I go SWITCH or Motor? Is there a way to trouble shoot window???? Fuse good Drivers window operates.
Pull the door panel off and take a look,one of the runners may have come loose,do a test to see if the switch is getting power,check for loose connections.
Ok will try to pull panel off this weekend.
Went to AUTOZONE bought a Regulator and motor for $59.00 going to install. Regulator looked good but could not get motor to turn over and all the rubber seal looks good.
