Honda Detailing Talk about any Honda detailing questions here.
What foam would go between a spoiler and the trunk lid?
Old 09-29-2018, 06:54 PM
Honda_Addiction's Avatar
Member
Default What foam would go between a spoiler and the trunk lid?
The spoiler I have decided to put onto my car came with foam attached to it. It's pretty dried out so I'll have to remove that and replace it. What foam should I use?
Thanks!
Old 09-30-2018, 01:00 AM
i have used the following to install spoilers. weather strip with stick on one side, with stick on both sides, scotch double sticky side tape, rtv sealant clear, polyurethane tape. all work good. make sure the surface is clean. isopropal alcohol
Old 09-30-2018, 01:08 AM
Member
Weather strip, sticky on one side? Where would I buy that? It needs to be about a 6 inch x 6 inch piece that I can trim down.
Rubbing alcohol? Thanks.
Old 09-30-2018, 01:22 AM
home depot, lowes, auto parts, auto paint supplies, rubbing alcohol to clean surface before adhesive to stick. sticky on one side was used when experimenting on several different spoiler to test on cars. easy to remove off the car deck lid vs. leaving on for ever, use double stick surface.
Old 09-30-2018, 12:37 PM
Member
Thanks, I'll check next time I'm out.
I believe though, the 1998 to 2002 Accord trunk lids (and perhaps years after) have places punched into the trunk lid underside indicating where the factor spoiler mounts. Anyone know for sure?
Old 10-02-2018, 08:06 PM
Member
Old 10-03-2018, 08:20 AM
Member
Uh oh! Read the "question and answer" section!
What about this instead?
Amazon Amazon
Shaun Smith
10-16-2015 05:24 PM
buzzking
03-29-2014 01:56 AM
G-Man
06-17-2013 09:28 AM
devastator187
09-26-2008 10:47 AM
BradJFelix
04-25-2006 05:26 PM
Quick Reply: What foam would go between a spoiler and the trunk lid?
