03 pilot wheel offset
Ive seen alot of people say no to wheel spacers. But no one seems to specify what offset to look for in new wheels. I want to bring my wheel out about 1in. Is it worth getting new rims? If so what offset should i be looking for? Or should i just get a set of good spacers that have pressed in lugs. Thanks in advance.
welcome to the forum. spacers are not recommended due to the wheel center line is put out of ctr and causes more wheel bearing load. bearings are built better now but still will fail eventually where stock will rarely fail. if you decide to get off set spacers, try to obtain a rim that can put the ctr line back to or close to original. if your spacer puts the wheel out 1", find a rim that if 1" in from stock.
