2011 Honda CRV, can't line up wheel bearing assembly with strut bolts front right si
You need to jack the knuckle up.
Take a picture from further back so I can see it all.
Spoiler
I can't tell what you are struggling with. Raise and lower until it lines up enough to get a bolt in. Once you have one it is easy.
(Post 39890)
thanks for your reply. |
Is the upper part of the strut in the correct mounting holes?
Originally Posted by avisitor
(Post 39892)
Originally Posted by BIllyblues
(Post 39894)
yes it is thank you for replying, should i worry about sway bars ?
May just needed to be forced into correct position? Sway bar? If it was not moved then probably not |
The sway bar is connected to the lower control arm. Did you disconnect it? That may be why you are not getting it up in place.
| All times are GMT -5. The time now is 10:26 AM. |
