89 crx b18 gsr jdm swap
Old Mar 11, 2006 | 01:01 AM
bobby's Avatar
Default 89 crx b18 gsr jdm swap
should i go with a b18gsr/ or b16a motor(both jdm)what would be better. and is the swap hard???
Old Mar 22, 2006 | 03:28 PM
biglu gsr's Avatar
Default RE: 89 crx b18 gsr jdm swap
they both are the same you will need the b series motor mounts and also the axles and the wiring harnesses its reall the same but if you really want to run hard i will go with the b18c1 swap because i did the same in a 91 crx si and it ran good with a acura integra ls cable tranny
atrain33
Aug 30, 2011 02:13 PM
atrain33
Aug 4, 2011 07:05 PM
poweredbyhonda89
Feb 1, 2010 01:51 PM
Rhondahunnie
Sep 8, 2009 04:43 PM
asoberbassist
Nov 16, 2006 08:05 PM
