94 integra ls????
Old Oct 26, 2009 | 08:04 PM
DC2Misfit's Avatar
Default 94 integra ls????
sup guys. i have a 94 integra ls and im not too sure what i wanna do to it.
i was thinking of throwing a turbo on it. since its a low comp motor it should do pretty well on boost. but im not too sure about the power itd make or if itd even be worth the kit and the tune (kit is about 800 and tune would be 500)
so if any of u guys have and suggestions let me know.
Old Oct 27, 2009 | 11:10 AM
the cost is good, if your engine is in good shape and you can do the installation, you'd get quite a bit of hp out of your engine. Be sure to cool down the turbo after each run, oil will coke up in the turbine hot section. Also if your at altitude ( mountain skiing ) it will keep the power up vs normal asperated engines.
Old Oct 27, 2009 | 11:50 AM
DC2Misfit's Avatar
whats about hp wise anybody got any numbers??
Old Oct 30, 2009 | 12:17 AM
91haydenSI's Avatar
it depends.. your motor stock gets 142 hp @ 6300 rpm & 127 ft·lbf @ 5200 rpm.. with a turbo running about 8 psi i would say you can get upwards of 250whp.. and thats cutting it short to be safe... BUT i wouldn't suggest it without some motor work.. im not saying all new internals but atleast get new rings, seals, bearings, and gaskets
srt42004n
Aug 11, 2006 07:55 PM
Lewis22
May 19, 2006 01:08 AM
tegsr
May 9, 2006 09:33 PM
zackclub109
Oct 24, 2005 03:42 PM
zackclub109
Oct 20, 2005 02:43 PM
