-   Honda Forum Help & Suggestion Center (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/)
-   -   98 civic code engine light emissions (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/98-civic-code-engine-light-emissions-8053/)
Sikstikchik Oct 14, 2012 06:14 PM
So my check engine light came on. I checked it and two codes read: P1457(emissions) ; P0303(cylinder 3 misfire). What do these mean and how can I fix them? I also might have an exhaust leak which may be the cause of something wrong with my fuel injector. Please help!? Thanks :o:o
acmech52 Oct 26, 2012 09:45 AM
welcome to the forum. if you have high milage on your engine and have not done a tune up, check/change or replace the spark plugs, plug wires, and (clean ) injectors. then have the codes removed and see if they return.
