99 civic si engine problems
Old Aug 15, 2008 | 05:19 PM
buster87's Avatar
Default 99 civic si engine problems
I have a 99 civic si with a b16a2. It blew a https://hondaforum.com:80/99_civic_si_Misfire_and_a_dead_cylinder/m_6941/tm.htm#]head gasket[/URL]. after fixing that about a day later the check engine light come back on. Computer scan shows a misfire on all cylinders an cylinder #2 is dead. Ive tryed replacing ignition parts distributor,plugs,wires,etc. and fuel system parts. If anyone has any idea wat it could be or has had the same problem please let me Know.Thankyou.
Old Aug 19, 2008 | 09:47 PM
Default RE: 99 civic si engine problems
have you checked your o2 sensors, this sometimes goes out if you send anti freeze or oil or excessive fuel through the exhaust system, recheck your codes after you reset them and run the engine for a while.
wickedx90x
Jul 24, 2014 10:54 AM
Ricers 4 life
May 14, 2013 08:18 AM
wildplumdx
Jan 5, 2011 10:31 PM
honduh
Feb 1, 2009 09:37 PM
bchambers05
Jan 6, 2007 06:25 PM
