Clothing hook in rear compartment 2018 CRV
can anyone help me with how to remove the clothing hanger in the rear of the car? I’m trying to install a trailer wiring harness, but when I attempt to pull out the plastic panel, I am unable to move it far enough out due to the hook. Thank you for your help! https://cimg2.ibsrv.net/gimg/hondafo...a6507e363.jpeg |
Does that hook lever out like a door handle? If so look to see if the small panel can be prayed out,there maybe a release under it. |
https://cimg3.ibsrv.net/gimg/hondafo...dbd8203d9.jpegWhen I flip the hook up, you can see this white plastic piece inside. There are no screws and the housing for the hook is all one molded piece. |
Try popping off the trim around the hook with a thin blade screw driver" gently". See what it covers ,it may be hiding a release. |
