drivers side window problem
i have a 04 civic ex 2dr. i am having a problem with my window coming out of the white pusher on the regulator that pushes and pulls the window up and down. i have tried adhesive and glue to bond the window back put it keeps comin out. is there a way i can fix this for longer than a week at a time?
Welcome in,is the piece your are refering to bonded to the glass or in a slider?
yes it is the lil peice that the window is bonded to with black glue looking stuff (mine was) and i cant find nothing strong enough. hope this helps if not let me know. thanks
Go to a glass shop and ask what type Epoxy they use,they may even give you a sample,If they can't help, buy a two part epoxy and follow directions.
