lowlife9 |
04-19-2014 06:40 PM |
try this Close all the doors and the trunk. (it's best to be sitting in the driver's seat while doing this) Within 1 to 4 seconds of each other, complete the following steps. (do step one, within 1 to 4 seconds after doing step one, do step two, followed by step three within the same time period, then step four, five, etc.) 1. Turn the ignition switch ON (II) 2. Push the lock or unlock button on the remote. 3. Turn the ignition switch OFF 4. Turn the ignition switch ON (II) 5. Push the lock or unlock button on the remote. 6. Turn the ignition OFF 7. Turn the ignition switch ON (II) 8. Push the lock or unlock button on the remote. 9. Turn the ignition switch OFF 10. Turn the ignition switch ON (II) 11. Push the lock or unlock button on the remote. 12. Confirm you can hear the sound of the door actuators. Within 1 to 4 seconds, push the lock or unlock button again. 13. Within 10 seconds, aim the transmitters (up to two additional ones) whose codes you want to store at the receiver, and press
