The key is stuck in the ignition
Has anyone else had a problem with a key stuck in the ignition? If so, how did you fix it? Any help appreciated. Thanks.
Mike |
Depends on how it is stuck in the ignition
If it is the gear selector not engaged in park then gear selector must be looked at If it is the ignition cylinder then the cylinder needs to be replaced If it is the steering wheel is turned to one side and has locked the key in position then move wheel to release |
Welcome in,most likely the steering wheel has locked it in,its happened to my wife three times as well as myself ,turn the wheel hard left while pulling the key it should release. Good luck.
| All times are GMT -5. The time now is 07:47 AM. |
