-   Honda Forum Help & Suggestion Center (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/)
-   -   Oil Drain Plug (https://hondaforum.com/forum/honda-forum-help-suggestion-center-35/oil-drain-plug-15587/)
CRVDon67 Sep 23, 2021 12:27 PM
Oil Drain Plug
Has anyone replaced factory oil drain plug on a CRV with a Valvomax drain plug? I am thinking about using the Valvomax drain plug on my wife's 2009 CRV,. Would like to know if anyone has used those and had problems with getting the Valvomax plug threads to fully engage the oil pan threads so that there is a good tight leak free fit.
Have had several people recommend the Fumuto oil drain valve, but I do not like the design.
manishhpsetup Oct 12, 2021 07:22 AM
Good Job
hi
you can check a best job for you
Best Jobs
