Wiring issue's
My 1994 acura integra ls with a b20b swap. I need help i think when someone had this car before switched wires around when they did the swap. Just need to know which connectors go where it will reach up to about 4.5 grand but no higher like the ecu is in limp mode pulled engine code is 41 and ive reset the ecu a thousand times as soon as i start it up it the engine light comes on agian. Plus burns through plugs like no tommoroe. Went a mile up the road and they were allready black with white smoke coming out of the exhuast
welcome to the forum. wire diagram will need to purchase service manual or cd off ebay. if the 94 acura had a b20 swap the ecu should have been changed to accomodate the engine parameters. the black on the spark plugs means a little on the rich side. white smoke if the engine is warm is burning oil, or leaking into the combustion chamber thru the heads. park plugs can go for 100k miles easy if electronic ignition.
