15hp outboard won't start
Old 06-06-2018, 08:18 PM
stevemenzner@gmail.com's Avatar
Default 15hp outboard won't start
What are the common reasons the 15hp outboard won't start?
Old 06-06-2018, 08:48 PM
welcome to the forum spark, air, fuel basic needs for ignition. possible spark plug and or lead not good, no compression, air filter clogged not enough air, no spark coil bad.
Old 09-26-2019, 10:07 AM
RobertLang's Avatar
More info, pls. Recent problem or after sitting over the winter? Pulled and replaced plugs? Runs on starting fluid shot?
Old 09-26-2019, 12:37 PM
Runs on starting fluid indicates that it is a fuel supply issue
On some motors there is a valve that gets turned to shut flow of fuel to motor
It is useful especially when putting motor into storage for winter
If not the problem then need to check out delivery system
ultimatesalmonslayer
09-17-2017 05:50 AM
Coreytreat
06-18-2014 03:40 PM
hondaface75
01-01-2010 09:06 AM
TotalEclipseTinting
09-26-2008 11:55 AM
gixxerdude1979
12-17-2007 08:52 AM
Quick Reply: 15hp outboard won't start
