-   Honda Marine Engines (https://hondaforum.com/forum/honda-marine-engines-33/)
-   -   2009 25hp will not crank (https://hondaforum.com/forum/honda-marine-engines-33/2009-25hp-will-not-crank-9495/)
sdsherman Jul 1, 2014 06:18 PM
25 will intermittently not crank. Not even click when key is turned to start. If turned to on, I can start with pull rope usually on first pull. Battery at full charge, terminals are tight, and remote is in neutral. Had key switch checked at dealer last year and they said it was fine. Thoughts? Thanks for any help.
Partspak Jan 25, 2017 09:28 AM
First would be checking to see if you are getting 12 volts to the solenoid to energize the the two large post on the solenoid. Most likely you have two small wires on the solenoid, one will be grounded to the engine block and the other should have 12 volts on the harness side when turning the key to the start position. If you do not get 12 volts when turning the key to start position then the issue is on the harness or key switch. if that checks out fine then you can jump the two large wires on the solenoid to see if the engine turns over which means the starter is not the issue. If the starter turns and sounds strong then you would be replacing the solenoid. Here is a link to the parts diagrams.
JON
http://oemparts.partspak.com/oempart...a_marine/parts
