50 HP tachometer
have a malfuntioning tach on one of my two engines, does anyone know where the wiring from the engine starts... the connections to the tach look solid
thanks Phil |
RE: 50 HP tachometer
The tach will stop working when the charging coil fails. You should check that first because the dead charging coils will eventually result in a dead battery. There may in fact be nothing wrong with the tach. Good luck.
Jacques |
