8 hp Honda 4 stroke cooling issue
Old 06-30-2018, 02:47 PM
SLightly Salty's Avatar
Default 8 hp Honda 4 stroke cooling issue
I just picked up a 8 hp Honda 4 stroke. The water cooling the engine was fine and is now on and off. Before I pull it into the shop and go after the impeller is there anything else I’m missing? I did blow air through the hose to verify it was uninstructed. Seems like there’s pressure coming through the tube but not water. Any info appreciated.
Old 06-30-2018, 07:18 PM
welcome to the forum. I'm thinking you are correct on the impeller is not pushing water thru.
andyk58
08-11-2020 12:20 AM
dandingo1974
01-16-2020 09:43 AM
RobertLang
09-26-2019 10:03 AM
ironknight
07-22-2018 04:12 AM
Mack Stewart
11-30-2008 03:25 PM
Quick Reply: 8 hp Honda 4 stroke cooling issue
