BF50 will beep but only turn over at solenoid
I have a 2005 Honda BF 50. I just bought this motor used. It has had some carb issues but runs good enough once it warms up. Well today I am pretty sure I gummed up my carbs. I ran the battery to near dead and ended up being pulled in.
Since I bought it has a constant beep but it ran great and didn't go into a safe mode so attributed the alarm to fuel issues. I came home to troubleshoot it today and now it wont turn over. It will turn over at the solenoid but not on the key, but it still beeps. I have only bumped it, not started it and there is no green light on, just the red light. I noticed the oil was low. I assumed this must be a oil shutoff safety thing. I added oil, unhooked the battery, then tried again. It will turn over off the starter but not the switch. The fuse is fine because the beeping stops when I unhook it and starts again when I don't. Any advice to get this thing started would be very much appreciated. Best Regards, Matthew Sparks |
You should check to see if you are getting 12 volts to the starter solenoid (small wires). If not, I would trace the harness back until you find where you do have power. You might find that the key switch is bad.
http://www.PartsPak.com |
