Low Water flow from Discharge (tell tale)
Old Jun 17, 2019 | 09:32 AM
PaulAlford's Avatar
Default Low Water flow from Discharge (tell tale)
I have 2004 BF115HP and still getting lower water flow than think I should at tell tale. I no the T- fitting isnt clogged, but the water lines themselves "could" be. I just replaced the impeller and when I pull the T-fitting the water is gushing from the main hose so I know the pressure is good. I am getting a light flow from the tell tale but I needs to be stronger. I am connecting the garden hose at the flush port just below the cowling in the back of the motor (not the ear muffs) if that makes any difference.
Old Sep 26, 2019 | 10:05 AM
RobertLang's Avatar
Sounds like a blockage, someplace.
Old Apr 27, 2020 | 12:02 AM
Kevinstoy's Avatar
I had bee's build a nest in the outlet hose cooling box which caused this problem. it happened in two weeks while boat was sitting. Hope this helps you.
dandingo1974
Jan 16, 2020 09:43 AM
ironknight
Jul 22, 2018 04:12 AM
GCysewski
Jan 20, 2018 10:44 AM
kp2001
Jun 26, 2010 01:41 AM
vitovonantwon
Jun 30, 2008 07:36 AM
