-   Honda Scooters (https://hondaforum.com/forum/honda-scooters-31/)
-   -   2014 Metropolitan - Fuel Pump Will Not Prime - Short? (https://hondaforum.com/forum/honda-scooters-31/2014-metropolitan-fuel-pump-will-not-prime-short-13761/)
jpk_504 Sep 14, 2019 03:40 PM
Just picked-up a 2014 Metropolitan - like new (200 miles on odo), but has a weird starting issue. When outside temp is less than 75 degrees, it starts fine, but will not start when outdoor temp is in the 80-90 range.
Everything turns on, but the fuel pump sound does not happen, it just sounds like a short or a relay issue, makes a little buzz and then nothing. Turns over but will not fire.
Any ideas? Called dealer and they had never heard of the issue...
Mike875 Aug 4, 2022 03:04 PM
Starting issue
What wound up being the problem?
grcauto Aug 4, 2022 04:02 PM
He hasn't been here since he posted.
Need to check that the pump is getting proper voltage.
