Help get my Metropolitan running!!!!
2004 Honda Metropolitan CHF50
Got this scooter for free. It has been sitting for several years in an old garage. Here's what I've done so far. New Fuel Pump New Fuel Filter New Battery New Fuses New Spark Plug New Air Filter Changed engine Oil Changed Gear Oil Changed coolant Took apart & cleaned carburetor Cleaned out gas tank, new gas and Gumout carb. cleaner put in tank Current issues: 1. Kick start not starting scooter. Apply brake, turn key to ON, push Start button - just a click sound. 2. Pulled fuel line off carb. - turn key to ON - fuel pump just clicks a few times, no fuel pumping through line (again, this is a new fuel pump) Any help would be appreciated. Thanks. |
Sorry don't know much about this scooter.
Would check to see if there is power and ground at the fuel pump. Also check to see if there is spark. Maybe spray some starter fluid into in take to see if it starts |
Check battery and connections
battery should read about 13.7 volts to run everything right. All connections should be “bright and tight”. DC electrics are finicky.
Did you ever fix problem? What was resolution?
Originally Posted by Seapat
(Post 36306)
| All times are GMT -5. The time now is 07:47 AM. |
