1st Gen Ridgeline rear window not working
Old May 9, 2024 | 03:23 PM
Samo78's Avatar
Unhappy 1st Gen Ridgeline rear window not working
2008 Ridgeline is beginning to show it's age. I use the rear window a lot as it makes putting long objects into the cab easier. When I start the engine the dashboard light tells me that the rear window is open, pressing the button has no effect and the window is tightly closed already. The light turns itself off after a short period of time. The fuse is good and I haven't had any "burned electrics" smell in the cab. So obviously, I need to check the motor, but how do I find it? Thanks for your help. Cheers Sam
Old May 10, 2024 | 09:51 AM
Old May 10, 2024 | 10:33 AM
Samo78's Avatar
Thanks, this will be really helpful if the silicon trick doesn't work.
Old May 12, 2024 | 08:39 PM
Samo78's Avatar
The silicon trick worked, had to leave the windows open overnight, but it stays in a garage so no problem. I'll use the silicon more often than once every18 years from now on.
Old May 13, 2024 | 10:06 AM
Good to hear.
cot266
Aug 1, 2021 03:12 PM
FreshBoii
Nov 2, 2019 08:22 PM
Otispdriftwood
Oct 26, 2019 02:46 PM
Raven
Nov 5, 2012 08:07 AM
socal07
Mar 31, 2010 09:11 AM
