-   New Member Area (https://hondaforum.com/forum/new-member-area-5/)
-   -   2007 Honda Accord ex 2.4 code U0107 (https://hondaforum.com/forum/new-member-area-5/2007-honda-accord-ex-2-4-code-u0107-13537/)
Mark Emory May 19, 2019 08:20 PM
When replacing the starter I accidentally knocked some wires out of the connector going into the Throttle position sensor on the throttle body. So I rewired it and put it back together, but now I'm getting this U0107 code and the car is in limp mode.
What do I do?
https://cimg6.ibsrv.net/gimg/hondafo...4fea08f05c.jpg
acmech52 May 19, 2019 10:18 PM
welcome to the forum. u0107 says 1. faulty throttle actuator, 2. throttle actuator control open or shorted, 3. throttle actuator control module circuit poor electrical connection or broken wires. wonder if you put the correct lines in the correct socket holes, or perhaps the wires do not have good connection, or broken internal wire.
Mark Emory May 19, 2019 10:39 PM
Yes I'm sure they are plugged in the right spots.
How can I check each wire to make sure it's getting the proper signal, and that the fault isn't further back?
acmech52 May 20, 2019 01:24 AM
may need to get a hold of a wire diagram to see where the wires are pinned to . have not worked on a throttle system, sorry unfamiliar with this. I will need to do more research.
Mark Emory May 20, 2019 08:30 PM
Still haven't found the issue
acmech52 May 23, 2019 03:16 AM
sorry for the slow response, needed to do a bit of research. clear the code to see if it comes back by disconnecting the battery cable for 1 min. or using a scan tool to clear the code. if the code returns, check your connection where you repaired the wire and make sure the pins are in place and not backing out when the connector is resecured. if the the connection is good, check the the ground connection and clean it good,. clear the code and recheck. if the code comes back, you may have to remove the harness wrap and check to see if there are any damaged wires. also check the relay and fuse to be good. if all this does not fix the issue, you will need a diagnostic scan tool to ck the circuit to make sure the sensor and tac is good. again my apology for the slow response.
Mark Emory May 25, 2019 01:46 PM
Did all of that, nothing worked.
Where does the other end of the wire go?
Can't find any good diagrams
bucwheat May 25, 2019 04:36 PM
My suggestion is try one more time to clear the codes,also make sure all the wires make good contact in the plugs themselves.
Mark Emory May 25, 2019 04:54 PM
I've cleared the code a dozen times, its not going away.
And I've positive it's wired right and making good contact.
I'm afraid that I may have fried whatever that wire connects to at the other end. Does anybody know what connects to the throttle body position sensor?
chano Jul 7, 2021 06:43 PM
How do I remove the throttle position sensor?
What do I do?
https://cimg7.ibsrv.net/gimg/hondafo...8c448d420d.jpg
How do i remove the throttle position sensor? Do i just remove the black piece (and how? I dont see ant any screws attached to it). Or do i have to remove the entire bigger sliver plate its sitting on?
