need help!!!
hi i am new to this site and i need you guys' help, i have a 1993 honda civic coupe with a 1.5 liter motor and it was running fine till i parked it in my driveway for a couple of months....i warm it up every now and then but after a week i tried to warm it up again i tried to start it and it just cranks and wont run, i replaced my rotor , sparkplug wires , spark plugs and checked my rotor cap for sign of moisture.....i also pulled one of the spark plug wires and test it for a spark but no electric coming from it ...what should i do next??? thanks
welcome to the forum, coil/ignitor in the distributor, usually lesser cost to replace the the whole distributor. check on prices. Also make sure the timing belt is not broken or slipped.
thanks
thanks for your help ill check on those parts............
I can make educated guesses but without looking at it. But what I did want to say is I swapped out my whole setup so if you're in need of any replacement stuff i.e. new motor 1.5, tranny, ecu, harness, axle etc, lemme know. real cheap
