No air or defrost
Old Nov 2, 2011 | 10:37 AM
Brutal's Avatar
Default No air or defrost
2008 Honda Civic. Air died, so had it recharged. Didn't need it. Fan going full blast but nothing out vents. Will work off and on. Coming into winter. Need defrost HELP
Old Nov 3, 2011 | 06:23 AM
welcome to the forum. If no rrecharge needed, did you check the freon pressure unit. I beleive this unit tells the compressor to turn on or off if the freon pressure is low. may be bad.
Old Nov 3, 2011 | 01:37 PM
Welcome in.I agree,both relays are in the fuse block under the hood.
Old Nov 4, 2011 | 09:13 AM
Brutal's Avatar
It is still acting up, even with heat. I can hear to fan motor going full blast, but little or nothing from the vents.
Then the next day it works fine. I had some work done a bit ago, and the apprentice fried my computor. They replaced it. Could the new computer be the cause? It seems the vent "door" isn't working right. Just a guess.
Old Nov 4, 2011 | 09:28 AM
The controller on the dash for the vent doors is most likely bad.
Old Nov 4, 2011 | 04:25 PM
Brutal's Avatar
Can anyone find and fix it? On the dash-- I'm not sure I understand.
CrossCountryDriver
Aug 29, 2014 10:35 PM
babyblueeyes
Nov 10, 2006 09:42 PM
barley
Jul 27, 2006 09:11 PM
rydnlow1120
Jul 20, 2006 02:15 PM
Allnbrgdn
Jul 17, 2006 11:09 PM
