No air or defrost
2008 Honda Civic. Air died, so had it recharged. Didn't need it. Fan going full blast but nothing out vents. Will work off and on. Coming into winter. Need defrost :confused: HELP
welcome to the forum. If no rrecharge needed, did you check the freon pressure unit. I beleive this unit tells the compressor to turn on or off if the freon pressure is low. may be bad.
Welcome in.I agree,both relays are in the fuse block under the hood.
It is still acting up, even with heat. I can hear to fan motor going full blast, but little or nothing from the vents.
Then the next day it works fine. I had some work done a bit ago, and the apprentice fried my computor. They replaced it. Could the new computer be the cause? It seems the vent "door" isn't working right. Just a guess. |
The controller on the dash for the vent doors is most likely bad.
Can anyone find and fix it? On the dash-- I'm not sure I understand.
| All times are GMT -5. The time now is 06:56 AM. |
