-   New Member Area (https://hondaforum.com/forum/new-member-area-5/)
-   -   Parking Brake Pad Replacement??? (https://hondaforum.com/forum/new-member-area-5/parking-brake-pad-replacement-5810/)
Misterg Apr 27, 2010 02:49 PM
Hi All
I'm new to HF. I have a 2005 Pilot and just replaced front and rear brake pads (with Wagner Thermo Quiet) the rotors seem to be ok so I did not replace them. I still hear a faint noise coming from the rear only when back up or go forward for a short distance. Is there a parking brake pad? Should I have replaced it? If so where is it located?
Thanks in advance for any help, Misterg:)
acmech52 Apr 28, 2010 02:17 AM
your rear brake pads is the parking brake. when you apply the emer brake the rear pads are holding. If you live in a place that has moisture at night, the first brake apllication will make a light scraping noise. If the noise continues, you may want to take the pads off and view it for metal transfer.
Misterg May 3, 2010 12:11 PM
Thanks so much for the info
