Upgrading the factory stereo options/questions.
Old Feb 24, 2015 | 02:46 PM
jad's Avatar
jad
Default Upgrading the factory stereo options/questions.
Hi All!
I'm new to the HF forum, sorry for the lack of info on my profile, but I will update it soon.
Anyways, I have a 2014 accord cpe EX-L. I love the car, but the sound quality of the stereo could use a little help.
Since it's an EX-L, I do not want to remove the radio since its heavily integrated with the car. I found out the factory amp is a separate unit from the radio. If this is true, is it simple enough to replace the factory amp with an aftermarket amp having the same number of channels with only needing some sort of wiring adapter/harness?
I saw some insane professional factory installs on an accord using a DSP, but that's way overpriced for me.
Old Feb 25, 2015 | 08:21 AM
Welcome to the forum. If your car is under warranty, talk to your service mgr, ask if you purchase the part you want to mod, will the warranty still be good if they install it.
Old Feb 25, 2015 | 07:36 PM
commonname's Avatar
Member
I would agree with this comment. This would be the safest way to keep your warranty. Welcome by the way...
Old Feb 28, 2015 | 02:29 PM
lowlife9's Avatar
if you upgrade the amp by itself your just going to blow the cheap factory speakers then be worse off then before.
Old Mar 1, 2015 | 09:33 AM
jad's Avatar
jad
Default thanks!
Thanks all for your replies!
Ill def check with a Honda service manager. And if changing the amp is straight forward, i most likely will swap out the factory speakers.
Old Mar 28, 2015 | 06:55 AM
shanewilsonjr's Avatar
Member
Welcome....................
S-LudeDan
Nov 11, 2009 02:04 PM
zdcarver0430
Oct 2, 2009 07:46 PM
jgsparks
Jan 2, 2009 03:35 PM
Palindrake
Mar 4, 2008 11:32 AM
DamonC
Jan 24, 2007 10:33 PM
