2005 Oddessey sliding door falls off hinges
My Honda Oddessey is starting to fall apart. I'm not looking to replace quite yet so I'm hoping for some guidance. One of the sliding doors has broken. It is now securely locked but the beeper that says it open is going off. I know this is an important safety feature so Im not sure it there is anything I can do to turn off that beeping but its getting annoying so I figured I'd ask.
Welcome in,I'm not sure if this will work but on my truck I traced the sound to a module under the dash and unplugged it,or maybe pull the fuse but I'm sure other warnings would be affected also like you headlights or keys left in ignition. Something else that may work is tape the switch on the door closed so it thinks it has made contact.
Jschoend
Apr 25, 2019 01:50 PM
