This is likely caused by your xm or tuner failing. They are also the first units on the MOST (Media Oriented System Transport) bus for your van. The Display is also on that Ring network. If one fails, they all fail.
It might be a loose cable, related to the recalls or the component might actually be failing.
You can run the diagnostic on the system by going to Settings in your Gauges and hold the hang up button and enter button at the same time on the steering wheel for about 10 seconds.
