Don't run over Boat Anchors, Help!
Ran over a boat anchor with my 10 Odyssey gashed my control arm, looking for a replacement. Does it matter Cast Iron vs Aluminum? Does it need to be honda parts or are there other places I can get it and will they be an ok quality? Any experiences and tips with replacing the front lower control arm?
Did you do a proper inspection of the suspension?
You want to make sure there is nothing else that needs to be done.
Do it once and be done??
If you do not live in the rust belt then the procedure is fairly simple
You will need to get a wheel alignment done after replacement of the lower control arm
It is always best to use genuine Honda parts
It may be more expensive but you know it will be the right part
And not something that is close to the specs for your Odyssey
Tequilamockingbird
Dec 21, 2016 08:00 PM
rupenzelleo
May 9, 2015 05:48 AM
