High pitch hissing sound
05 Odyssey Exl high pitch hissing sound when accelerating fm 37-55 at 2000-2300 rpm n seems coming upfront. Replaced both front bearing n hub assembly n still hearing same. Checked all mechanical, checks good w/ no play. rotated 2 yr old tires, balanced n did alignment n still hearing same. I heard same problem at the back before n replaced bearings n hub assembly n sound disappeared. That’s why I did same to the front. Transmission is really good n never have problem. Any idea, suggestion, experience is much appreciated. |
welcome to the forum: possible leak in the intake line.
no intake leak
have you leaked checked all vaccum lines. power brake line. also check to see if the serpentine belt tensioner is quiet. did you also check the intake manifold at the head area.
Hi-Pitch
Car runs n shifts really good, engine so quiet n smooth during idle n w/ no vac leak. Has new serpentine belt. No CEL n only have Ars-Seat belt indicator problem n recently replaced drvr seat belt latch n fixed problem. Transmission never have no problem. Accelerating from 40-55 when high pitch is heard at 2000 rpm. Plan to replace timing belt kits n will continue to check as recommended. Thank you. |
Do you have a cold air intake type air filter? After awhile they become a little dirty and make noise.other than that maybe a vacuum leak. |
High pitch
I replaced all my cars filters with KnN filters n clean them annually when I do oil change, mobil1 15k, annual driving 4-6k. Odyssey 105K, runs really great just worry me this hi-pitch? |
Check to see if you have a retainer clip broken on the brakes |
Originally Posted by bucwheat
(Post 30446)
When you do eventually find out what it was please let us know. |
