info needed on Touring run flat tires
Old Jul 16, 2007 | 01:45 PM
raymondjiii's Avatar
Default info needed on Touring run flat tires
Does anyone know the following:
1) Are these wheels hub-centric or lug-centric?
2) Can these wheels be balanced on a regular tire balancer?
3) Can you rotate these tires yourself or will it screw up the display as to what tire is low on pressure?
4) Can the run flat option be disabled (such that you can put snow tires on - if that's even possible given question #1.)
Old Dec 2, 2007 | 07:42 PM
VQT's Avatar
VQT
Default RE: info needed on Touring run flat tires
You can rotate any tire yourself. I read somewhere on other odyssey forum regarding runflat related that Arcura MDX have the same function (tire pressure monitroing) as the the Odyssey but without runflat tires. All we need to do is to find a set of rims/tires that are the same dimentions as the MDX then wefit it to our Odyssey. I think is is only the sensors inside the tiresthat we need to have. The new 2008 Odyssey touring have two option one with runflat and the other with regular tires. Both model have TPMS.
iceblitzed
Sep 16, 2014 09:45 AM
dodger
May 29, 2014 05:09 AM
pilot916
May 20, 2013 07:03 PM
hunter
Jul 30, 2010 09:54 AM
ozuzz
May 20, 2007 08:57 AM
