info needed on Touring run flat tires
https://hondaforum.com/file:///C:/DO...reenshot-1.jpgDoes anyone know the following:
https://hondaforum.com/file:///C:/DO...screenshot.jpg 1) Are these wheels hub-centric or lug-centric? 2) Can these wheels be balanced on a regular tire balancer? 3) Can you rotate these tires yourself or will it screw up the display as to what tire is low on pressure? 4) Can the run flat option be disabled (such that you can put snow tires on - if that's even possible given question #1.) |
RE: info needed on Touring run flat tires
You can rotate any tire yourself. I read somewhere on other odyssey forum regarding runflat related that Arcura MDX have the same function (tire pressure monitroing) as the the Odyssey but without runflat tires. All we need to do is to find a set of rims/tires that are the same dimentions as the MDX then wefit it to our Odyssey. I think is is only the sensors inside the tiresthat we need to have. The new 2008 Odyssey touring have two option one with runflat and the other with regular tires. Both model have TPMS.
| All times are GMT -5. The time now is 10:30 AM. |
