Keyfob only works if car is running
Old Jan 15, 2021 | 01:50 PM
2008HondaOdyssey's Avatar
Default Keyfob only works if car is running
So I installed a aftermarket remote (CM-DC3) start in my 2008 Honda Odyssey. After the installation I have an issue where the keyfob will only unlock/lock if the car is on. My OEM keyfob also no longer works at all. My suspicion is maybe a fuse blew somewhere, but I can't seem to find any fuse specific to this. Does anyone know what might be wrong?
Old Jan 15, 2021 | 08:48 PM
The aftermarket remote may have interfered with the Honda set up.
It seems the fuse tap for aftermarket remote might be on a fuse that is only hot when engine on??
Short of that then would be a fuse.
Best to use test light or multi meter
Each fuse has two test pints. One above each leg of the fuse.
Neg clip to ground or battery neg
The probe to each test point
If both side light up then fuse is good
If only one side then fuse is blown
If no lights then no power to fuse
There is a re-learn for the original key fobs
cdunlap45
Dec 17, 2018 02:10 PM
wheatieman
Dec 3, 2018 01:45 PM
2Honda2
Mar 29, 2011 07:15 AM
maineduckhunter
Jan 16, 2010 03:12 PM
