Sliding door cable will not retract
07 odyssey, drivers sliding door noticed the cable was hanging out on the side of the van (cable is not broken)?? Try to use switch on dash (might retract the cable) nothing but the beep sound. Tried a few more times,..... then nothing? No audible sounds at all? Cable wont retract,...nothing? Forced door open and closed manually. Is the "switch" to the cable motor toast (no power)? if so, where is that switch? Or,....gulp, is the cable motor shot? Plus, I did check all fuses, all good
Please reply!!!
Please reply!!!
Thanks for the reply grcauto and thanks for the link!!!! Before I start is there any way to check if power is going to the actuators? There was the audible "beep" trying the switch on the dash, outer door handle and inner door handle then,.... nothing. To me, there has to be some kind of power to door? not sure where to start? Or is the actuators the power source to start from? Are they like acting like a fried circuit? Again, thanks for the reply
The entire manual is there. Click on things in the breadcrumbs on the next lines.
Home >> Honda >> 2007 >> Odyssey V6-3.5L >> Repair and Diagnosis >> Body and Frame >> Doors, Hood and Trunk >> Doors >> Sliding Door >> Diagrams >> Electrical Diagrams >> Power Sliding Doors Circuit Diagram
pro multis · About Operation CHARM
Power Sliding Doors Circuit Diagram Part 1:
Power Sliding Doors Circuit Diagram Part 2:
Power Sliding Doors Circuit Diagram Part 3:
Power Sliding Doors Circuit Diagram Part 4:
guitar548
Jun 21, 2023 03:34 PM
