07 cr150f front brake problem
my sons new (1 month) 150 has a problem that I can not resolve with the front disc brake. As he rides and uses the brake lever, the lever gets more firm and finally freezes the brake pads onto the disc and the wheel is not movable. It's as if the braking pressure applied from the lever never realeses after being let off. The only way we can make it work again is to bleed the pressure off the system and start over. Again after 30 minutes or so, it starts to lock if he uses it. Honda doesn't seem to know what it is either. Any suggestions? Thanks
Joe |
[Deleted]
[Deleted by Admins]
| All times are GMT -5. The time now is 06:03 AM. |
