2006 pilot
Old Dec 12, 2020 | 04:20 PM
tedeton's Avatar
Default 2006 pilot
pilot has miss fire on #2 and #5 cylinders. normally on start up. hav echecked valve adjustment,replaced plugs and coils. no change, sometimes it will set a 2647 code for vvt. ive replaced it and have cleaned the screen mulitiple times. still get miss fire on 2 and 5 .
Old Dec 12, 2020 | 11:27 PM
welcome to the forum. might VERIFY to check, Firing order for 6 cylinder 3.5 is 1 4 2 5 3 6 when you say #2 cylinder it is piston #4, and #5 cylinder is piston 3. can also be dirty injectors. vacuum leak or low compression. per Drivetrain Resource
DoubleDown778
Sep 19, 2020 09:49 AM
Sinskyu
Nov 3, 2017 12:14 PM
TheJoeCruz
Aug 15, 2013 09:26 AM
alfredo
Jun 17, 2009 03:14 AM
vdavenp802
Aug 26, 2008 03:51 AM
