2009 Honda Pilot Rear Air Not Working
For over a year now my rear air will sometimes work and then go out for long periods of time. Just randomly starts to work again. Hasn't worked in sometime now. I have read very little info. on this problem. Possibly a transistor by the drivers right foot area or something. Does someone have conclusive information for this fix? Leads to any articles or whatever would be greatly appreciated!
On my pilot rear air won’t work unless the mode is set for upper only. Hopefully it’s something simple like that.
other wise open that panel in the console near the front of drivers seat. Clean the screen. I’ve posted a link to a post on another forum. You should do some searching over there. There is also a post about just replacing the diode that causes the problem if you can solder. Last I looked the module was almost $100 at the dealer. https://www.piloteers.org/forums/69-...5=#post1084585 Post to module so you can see what it looks like. The one linked may or may not work in your vehicle. Module |
