2010 honda pilot radio won't turn on
Hi I have a 2010 Honda Pilot that I replaced the battery yesterday and I haven't been able to turn on the radio. it doesn't give me the option to put in the code. It's like the radio has no power going to it. Please help.
Welcome in,you did check the fuse and fuse links ,right ? If notand the radio doesn't have a security code, and all the fusible links and fuses check out, you'll have to do more diagnostic work to figure out what's going,did you jump start it?
Did u find a solution? I have a 2009 EX-L and im having the same problem. I noticed that the rear climate control stopped working as well and im not getting cold ac. its just blowing hot air.
