2015 Pilot Power Steering noise
Hello, first time post.
i have a 2015 Honda Pilot with 59k miles. The power steering pump has started making noises after driving around for an hour or so. At first it sounded like a transmission noise because you could hear the sound while shifting gears, but after looking under the hood it seems to be the power steering pump is making the noise. I can cut car off for a few minutes and start it up and noise goes away. I have read of the older models having o-ring problems but that doesn't seem to affect this year model. Any input would be helpful, thanks |
Welcome in,first off did you check the fluid level,second at 50K miles I would try having the fluid changed,good luck.
