road noise
what a lot of road noise for such an otherwise well built truck. You can really tell where they did not put the $. My Suburban is a much bigger echo box but is much quieter.The audio system is probably pretty good but the background noise ruins it. Does anyone have experience quieting the din? Dynamat? Where do you put it to get the most reduction of noise? Doing everything gets pretty expensive: $700- 1000.Thanks for any help. (08 PILOT)
welcome to the forum. have you checked the type of tires you have compared to the suburban? Tires make a lot of noise. Also I have used noise damper a spray that you use on the fender and undercarraige ( not on the muffler ) to quiet the vehicle noise down.
| All times are GMT -5. The time now is 06:54 AM. |
