-   Pilot Forum (https://hondaforum.com/forum/pilot-forum-16/)
-   -   Transfer Case Fluid Change (https://hondaforum.com/forum/pilot-forum-16/transfer-case-fluid-change-5830/)
fjpthree May 1, 2010 08:37 PM
My 08 Pilot is due for a transfer fluid change. Does anyone know where the drain plug is located and what type of fluid should be used?
kink_27565 May 3, 2010 12:09 PM
I ampretty sure that is a sealed system you cant do it with out hooking it up to a pressurized system... I had a 09 Pilot and it was sealed.
fjpthree May 4, 2010 07:51 PM
thanks....sooooo does that mean I have to take it to the stealership?
kink_27565 May 6, 2010 06:34 AM
Yup unless you got a pressurized home system.... but its not too bad its about 200.00 bucks just dont take it to a honda dealership then its like 400.00 use a good privately owned shop
