endlesstricks |
09-25-2012 11:52 AM |
having some issues
Having problems with my 96 lude have a miss in cylinder 2 it spits and sputters backfire out intake time from time timing is good map is good tps is good new distributor plugs wires ,then runs fine some times doing compression check today checked head gasket I'm good there haveing the worst time ever finding a problem with this car, I ohmed out the injectors they are all the same it don't miss constantly either certain rpms its a h23 if that helps to
