DTC codes after timing belt replacement
Old 11-24-2017, 09:01 AM
jkl2455's Avatar
Default DTC codes after timing belt replacement
'06 Ridgeline in which I just replaced the timing belt, hydraulic tensioner, tensioner pulley and water pump. The engine now has a difficult time at starting and running, but when it does run, the ECU is displaying P0344, P0389 and P2101 codes. The vehicle has 210k miles on it.
When the engine does start and run it will idle well, but will not accelerate (hence the P2101 code)
I've double checked connections to both the crank and camshaft position sensors, both are OK.
Is it possible for either of these sensors (both are original) to go bad and to trigger DTC's for either one?
Thanks in advance!
mrpassnh
04-09-2017 11:47 PM
ailwyn
01-08-2009 05:54 AM
sandyg645
10-20-2008 06:19 AM
mechanic
04-24-2007 03:24 PM
Quick Reply: DTC codes after timing belt replacement
